Help Identify Husqvarna 350 Cylinder
CrufflerJJ
6:11 PM
Ohioooo
I got a Husky 350 saw recently cheap off Craigslist, and have it disassembled to replace a torn intake manifold.
The cylinder is aftermarket, and has a capital-H-in-a-circle logo on the cylinder base. Is this Hyway's mark?
Just wondering....
Thansk!
d.l.d
5:11 PM
Arkansas
The hyway stuff I've bought only has an H with no circle if its marked at all. I have a Hyway 460 jug i got and it just had 57 stamped in the base. Just a word of advice if you didn't already know. Get a new revised metal clamp for the intake boot or you will be putting another top end on that thing soon.
CrufflerJJ
6:11 PM
Ohioooo
I had heard about the metal clamp. As purchased, this saw had a high quality nylon cable tie as a clamp. Spiffy, huh?
I've got an OEM Husqvarna clamp on order (it comes with the intake boot), but don't have an Oetiker tool to secure it. Can I use regular pliers on the clamp...or even use a stainless steel hose clamp in place of the official clamp?
Cut4fun
Redneck Chainsaw Repair
6:11 PM
Ohio
Easy to install the new metal clamp = patience. Needle nose pliers and I found locking needle nose work best.
d.l.d
5:11 PM
Arkansas
Oh, well I'd just re use the cable tie if you can, ha. Id use the supplied clamp. Its been awhile but i believe i used needle nose.
tickbitintn
5:11 PM
middle tn
so are you guys trying to say bailing wire is NOT the proper clamp????
i sure wish i took a picture of it.....:BangHead:
Fishnuts2
5:11 PM
SE MN
A needle nosed vice grip works best for that clamp.
Onan18
OPE Sponsor
6:11 PM
Georgia
Patience works best for those clamps, they are aggravating little devils.
Joe
Wagnerwerks
6:11 PM
Pa
That doesn't look like a hyway mark. It's like a cursive h.
jake wells
no longer here
5:11 PM
ky
put a little around the intake horn of the cylinder when you replace the intake boot.
use a metal clamp not a plastic clamp because they can cause headaches.
idiotwithasaw
5:11 PM
Ky
I still can't see all of the picture. Wish they would hurry up and fix it.
