Help - Clutch replacement
McCrazy79
OPE Member
7:13 PM
Daytona
Received a used ms250 chainsaw, it is missing a side cover and a clutch. Can anyone tell me what pieces I need to get the saw up and running again?
McCrazy79
OPE Member
7:13 PM
Daytona
Thanks, do you recommend a certain type of clutch drum?
Jimmy in NC
7:13 PM
North Carolina
Drum will dictate the pitch chain you can use. Most common on an 025/MS250 is .325 chain. I personally prefer a 3/8 Lo Pro or "Picco" chain setup off of an 021/MS210. I find that size chain matches the saws power much better.
TXChainsawMechanic
New OPE Member
7:13 PM
Newport News, VA
You don't need everything that's shown in the Illustrated Parts List that atpchas posted . . . just parts 1 thru 6 and just one sprocket. I agree with Jimmy in NC that 3/8 Pico is the way to go . . . and part #1123 007 1001 will give you everything you need for that . . . will also save you money in the future, since you'll only need to replace the rim sprocket (instead of the whole drum) when it wears out.
Jimmy in NC
7:13 PM
North Carolina
As TX stated the Spline drive setup is ideal. That and open the muffler up a little and they become a nice little beater saw.
Hokie94
New OPE Member
7:13 PM
Virginia
+1 on the picco setup for this saw, it makes a noticeable difference.
KZ1000
7:13 PM
Ohio
Good luck with the saw, hope it treats you right.
cgraham1
4:13 PM
Nor Cal
Did someone run this saw with the brake on?
