Granberg file n joint
Hilsay
Active OPE Member
4:13 AM
SWMO
When using the file n joint do you set the guide angle and top plate angle or just the top plate angle and zero the guide angle?
sundance
5:13 AM
SW PA
Depending on the chain specs (and guessing a little at your question), I set either 30 degrees and 0 down (most semi-chisel) or 30 degrees and 10 degrees down on file for most chisel chain.
Philbert
Chainsaw Enthusiast
4:13 AM
East Dakota
The Granberg will let you set:
- top plate angle 'A' (typically 30°);
- file height 'C' (typically 1/5 diameter above top plate);
- down angle 'B' (typically 0° or 10°);
- cutter length.
You can choose whatever settings you want, or use the manufacturer's specs. The key thing is that the jig will help you get whatever settings you choose accurately and consistently.
Philbert
sundance
5:13 AM
SW PA
when i use my granberg i use 0 and 30 on all chain seems like a happy medium
That's the way I did it for years and happy with results. I've recently started doing 10 degrees down on chisel, not sure it really makes much difference for what I'm doing.
Magic_Man
Oh Yea !
5:13 AM
SE Ohio
- cutter length.
Philbert
So when setting the up angle do you set height (C), before or after Up angle adjustment ? Right now I typically use 30 degree top plate and 1/5 height adjustment. Where would the 10 degree up angle come in to play as far as setup goes ?
Philbert
Chainsaw Enthusiast
4:13 AM
East Dakota
Good question- they are related. Have to look where the file exits the tooth (at the point / corner). I would want that to be about the same as when filing level.
Philbert
NorthcentralYooper
5:13 AM
Upper michigan
5 and 25 is where I'm at now. I may try out some different settings. When I went 10 degrees like it call for on Oregon chain I use it didn't cut as fast.
