Generic 91.6cc
Redfin
Meh...
5:09 AM
Central Pa
I just finished the saw this week. Nothing out of the ordinary as far as issues I found building it.
I did end up with extra rubber bits and the only thing missing from the kit was the nut for the roller catcher.
Case went together as usual with just some heat. I used all of the supplied parts in the kit but did swap for oem wrist pin bearing, clips and a WJ69.IMG_2513.JPG
Redfin
Meh...
5:09 AM
Central Pa
My buddy Kevin (Moparmyway) cut the piston for it including the jug. .035" popup on a 3* taper. Squish was cut on a matching taper. IMG_3171.JPG
Numbers after machining were 97/129/89. The only number I measured after were the transfers. I did not like the arc of the ex roof so I reshaped it. If I were to guess its probably at 94-95. I did eypoxy the intake and it should be around 81. Transfers are at 117.IMG_3165.JPGIMG_3176.JPG
67L36Driver
4:09 AM
I like the title “Generic 91.6cc”.[emoji108]
Steal it for my C’list add.
Redfin
Meh...
5:09 AM
Central Pa
Thanks Gunner. Saw feels good Dan. I didnt have time to try it without. I dont think it hurt.
