Gasket delete on 550?
Ketchup
Epoxy member
9:27 PM
Colorado
So I’m porting a 550mk2. The base cut is limited by the flange under the transfer covers.
But the base gasket is quite thick.
I didn’t love the idea of a full delete, so I cut a can.
Here’s the thing: That gasket looks like an insulator. Am I going to have overheat issues? MK1 was plagued by that. I feel a lot better only taking 0.020” off the base but do I need that insulation from the case?
Ronie
11:27 PM
NC
Isn't there enough material behind that flange to seal the transfers no matter how much you took off, just asking because I've only cut the base on a mk1? On my mk1 I cut the base and didn't use a gasket and so far I haven't had any over heating problems.
Ketchup
Epoxy member
9:27 PM
Colorado
How much did you take off the base?
Ronie
11:27 PM
NC
I looked at the picks of mine and I didn't take any good ones of that area, I know I took enough off to make a pop up. only pic I have of the base.
10:27 PM
One of the saw porters could probable give you an idea of what can be removed. @huskihl @Mastermind @Stump Shot
It can be reasoned out with a gasket delete, a reasonable squish band cut can be had with minimal machining to the base and have it land in a good working spot that the saw likes. Just a cleanup/finish base cut ought to do to get your squish tolerance to .020".
10:27 PM
Sorry, I can't remember and I didn't write it down.
For anyone doing mods I recommend getting some kind of note book so you can keep track of your build, otherwise like @Ronie just found out, knowledge learned will be lost for future builds and have to be done all over again from scratch.
MG2186
10:27 PM
Summer,IA
This is excellent advice! Especially for people like myself with CRS disease!
11:27 PM
I take .040” from the band and delete the gasket. No idea how much comes off the base. Never noticed it being an issue
Ketchup
Epoxy member
9:27 PM
Colorado
Couldn’t agree more. If I lost this little book 4 years of hard won info would be gone.
Here’s a shot of the jug that shows how the transfer cover surface angles down to the base opening. After 0.070” base cut the base would be very thin there.
I took 0.052” off the last one and left the gasket. Hasn’t cratered yet, but the flange is a wafer now.
Do you delete the Gasket, Steve? Or just take it all off the base? Any overheat issues?
10:27 PM
First thing I said is a gasket delete.
No heat issue has been reported as yet.
Approximately .005" + or - depending on jug and accuracy for a .020" ending squish.
