Welderman85
OPE Member
![United-States Country flag](https://opeforum.com/data/files/flags/shiny/32/United-States.png)
I have a few saw that need the lines replaced. Is tygon still the go to good line? I have sorta heard about echo and there black line. I plan to keep these saws so I would likenit to last. Thank you
When you pop the line off the carburetor and fuel squirts you in the eye, you have fuel.Can’t visually verify fuel flow with the Echo line. No thanks
I refreshed my 288 and put new tygon in itWhen you pop the line off the carburetor and fuel squirts you in the eye, you have fuel.
Too many issues with Tygon line over the years. Some of it would melt inside the tank, some of it would get hard inside the tank, some of it had liners that would separate from the rest of the line and fill the carb with goo. It’s just junk. I tear out every piece I find in a chainsaw
The issues stem from user error. Tygon is just a brand name, it’s imperative to match the type of tubing to the application. I’ve had zero problems using genuine Tygon in the proper applicationWhen you pop the line off the carburetor and fuel squirts you in the eye, you have fuel.
The yellow stuff is not meant for submerged applications. Good tip on not using it for impulse linesThe HyWay curly Q line works well for the Huskies that came equip with a curly line.
There is a big difference between actual Tygon line and the yellow stuff sold by Oregon and others. Still I only use Tygon for funny fuel applications where rubber won't last long.
Don't use Tygon on impulse lines, the heat causes it to loose the tension on the barb and will cause an air leak. I use Stihl impulse line or Echo fuel line.
