- 4:50 AM
- Dec 29, 2015
- Strong Island NY
I'd like some opinions.
Ported MS360. Perfect new piston and 200 psi after first runs. Laid the bar in a stump and beat on it for 4 strong runs. Saw was supposed to run fine before I got it.
New OEM fuel line and filter. Tank full. Stock Zama with compensating horn cut to fit metal filter, limiters trimmed. New impulse line and boot.
I did not check the tank vent yet, but it's the new style which rarely malfunctions. I will be checking that.
Saw starts right up. Idles fine.
I can tune high side pretty fat. Down into the 13's.
It will hold high tune for 1-2 seconds and then scream. Clocked it at 13,200 for 2-3 seconds, then takes off and hits 16k. Sounds like it's able to supply enough fuel in stock configuration for a bit, then runs dry. Like the metering side is full, gets empty, and then won't fill again.
My plan is to pressure test the new line and install a new carb. May fill tank and run with no filter just to see. Will pull current carb apart and look for any obvious issues.
Any ideas guys?
Any ideas guys?
