Flywheel thinkin
twinstaged
4:23 AM
Ohio
Anyone cut into a stock aluminum flywheel and see how the center hub is cast in place dimension wise. Specifically a 660 flywheel. I have a pretty good idea from looking, but more of the hub could be hiding under the surface. I guess I could sacrifice one to get the knowledge unless there is some "been there done" that from someone here? Thanks
Deets066
AKA Deetsey
4:23 AM
Where are you goin with this?
twinstaged
4:23 AM
Ohio
Two piece flywheel with pinned locations for timing degrees as a test tool or just run it. Just a random thought at the bench today.
Outback
1:23 AM
Seems like you could do that with two flywheels and an old crank end to chuck up in the lathe.
twinstaged
4:23 AM
Ohio
Yeah that was the plan. I'd probably make a mandrel with the same taper so I could run it between centers.
