First ever rebuild: Stihl 038magnum?
Manofstihl661
11:28 PM
Texas
Well I started cleaning and thought...I don’t remember ever looking in the intake side of the jug... :(
Guess this thread is dead quicker than it started...
As soon as I had to remove a strange piece of metal from the boot i knew it wasn’t going to be good. Looked in and knew where it came from immediately and decided cleaning the saw was useless so I pulled the jug. Guess I have a few parts maybe that I could dish out but other than that I’ll just practice taking it apart I guess.
Manofstihl661
11:28 PM
Texas
Cylinder doesn’t seem bad...maybe? I don’t feel anything besides the dark colored area which I’d assume is carbon deposit? Maybe it could be saved for if I find a better specimen later? I’ll get measurements and numbers in a second. Also a picture down around the crank coming.
Manofstihl661
11:28 PM
Texas
51.75 or so...so maybe 52 since my calipers were bought off amazon and either way probably have some leeway
Manofstihl661
11:28 PM
Texas
That's kinda odd damage... Lucky enough 52mm 038 psiton is easy to find.. Yes the cylinder is good.
I thought so too but I dont have much experience. I thought with the piston seemingly being destroyed it would have scarred up the cylinder at least too.
Wolverine
dilligaf
11:28 PM
For some reason, your pics aren't loading for me.
Do you have any previous experience with an 038mag? I rebuilt and flipped one a few years ago. It was a turd stock. Boat anchor weight and 60cc performance in a 72cc package. My ported 56.5 cc would rip it a new azzhole so after that I've never understood the lure of these saws.
This is how I bought it. Using the MM method of transfer removal, it cleaned right up.
After:
Wolverine
dilligaf
11:28 PM
Oh wow, just saw pics of the bottom. Not looking good. I was guessing you had transfer on the cyl.
Moparmyway
Its just a saw
11:28 PM
In a meeting
I’d split the case, inspect the crank/rod real good. If it checks out, install new bearings and seals.
Let’s see what you decide to do with it, have you ever split a case before ?
Manofstihl661
11:28 PM
Texas
Never split a case. So if anything I may go through the motion on it to an extent to get the experience of it. Then if anything I have spare parts for later and could find another builder or a runner or who knows. But I want to go through and learn how to check things and them apart at least if that makes sense
Manofstihl661
11:28 PM
Texas
No previous experience with one but I’ve always heard good things actually.
11:28 PM
Don't listen to any negativity about an 038 Mag because you can add some soup to them if you know how .Those Mahle cylinders are tough .I rebuilt one with a grenaded piston worse than that one and the cylinder didn't have as much as a dent in it . Even stock they do very well .The one I rebuilt had served over 20 hard years of service for a tree company and ten more after I rebuilt it and it was given to me .
That one is pretty funky inside .Soak it in a bucket of kerosene for a while to get all that sludge and crude off it .
Parts for the 038 mag are relatively inexpensive and pletifull in both OEM and after market .--good luck
Manofstihl661
11:28 PM
Texas
I appreciate the encouragement. I’m keeping an eye out for parts saws and such to supplement this one. It’ll be a long journey but eventually I’ll get it done
qurotro
Cookie Cutter
10:28 PM
Ar
038s are tough though they are heavy. I've seen guys ran diesel motor oil as a mix in them all day long without blowing it up.
11:28 PM
Seriously if anything a pound or two doesn't make any difference and if anything bucking on the ground is a help .You just hit the gas and it eats it's way right through .No hooking a dog and leaning on it hard .Fact I did two 15" maple logs yesterday with a souped 038 mag in almost no time at all . Just let -er-rip and move it along at about 16" apart .Roll it over with a cant hook and cut them all loose in a flash .Done--put the saw away and drink beer .There was about a face cord in those two logs and it took me maybe 15 minutes .Not bad for an old retired fart
OC455
11:28 PM
Upstate NY
So, how did this turn out or is it on the back burner?
