Johnar
New OPE Member
I have a 2014 X Mark lasers S60. The rocker switch for the throttle position seems to only be working when the clutch is disengaged call the dealer they said check the box that lights up. Under the control panel sometimes they get moisture built up from grass. Mine was completely clean. functions lit up on the control box when prompted to I felt the key switch plug in the back getting warm. One of the connections was rusty. I disconnected the key switch, clean the connection put it back on started the machine seem like it went in limp mode for a couple minutes shut off now won’t restart. Dealer tells me just unplugging the key switch from the back and plugging it back in won’t do any harm. Not sure if I was supposed to disconnect the battery or not, but they all say no answer makes no sense for the last couple years. Sometimes when you go to engage the blades, they won’t come on. I would have to shut the machine off and restart it in the blades to come on and be fine. Is the only reason I started poking around now, I have a machine that doesn’t start from cleaning
