Echo SRM 410U ?
mainer_in_ak
12:58 PM
Interior Alaska
Anybody know how to richen up the idle on these srm 410's?
Weird carburetor
EFSM
3:58 PM
Extreme southern IL
Weird carburetor
There is a little plastic plug in the middle of the carburetor rotor, right on top of the carburetor. Use a pick or Echo's special tool to remove it and that exposes a little flat screw, which is attached to the rotor needle. That's you idle mix adjustment.
mainer_in_ak
12:58 PM
Interior Alaska
There is a little plastic plug in the middle of the carburetor rotor, right on top of the carburetor. Use a pic or Echo's special tool to remove it and that exposes a little flat screw, which is attached to the rotor needle. That's you idle mix adjustment.
Thanks again for the info, greatly appreciated. I never would've found that darn low speed adjustment had u not told me. Wow that little plastic plug and adjustment screw are tiny! I ended up removing the round slide +needle assembly and carefully drilled out the plastic plug.
Once I found a flat tip small enough to fit down onto the float needle adjustment I got er richened up. I put a dab of blue loctite down in the threads.
EFSM
3:58 PM
Extreme southern IL
Hopefully that doesn't make it too tight. Usually there is a small spring under those needles to hold them in place even if the limiter cap is gone. Beside the needle is the old style cap to keep dirt out. You could pull them off with your fingernail, but they ended up with too many dead mosquitoes in CA.
mainer_in_ak
12:58 PM
Interior Alaska
Thanks alot! Good to know. I just kinda figured after having drilled out that darn plug, a tiny drop of loctite on the threads should keep the screw from backing out. She's nice n rich down low. Scary how lean it was on the low jet.
