Echo SRM-210
highroller_2024
New OPE Member
1:07 PM
Sparta, NC
I have an Echo SRM-210 that will start but when I start opening the throttle it dies. I've cleaned the carburetor multiple times and it still does the same thing. The frustrating thing about most Echo 2 cycles are that there is no fuel mix adjustment screws. The compression is just a little bit above 100 lbs. I was wondering what is the acceptable range for the compression is?
Thanks.
