LohmanBoy
Active OPE Member
- 1:14 AM
- Jan 30, 2021
- Lohman, Mo
I have an Echo CS530 that doesn't start. I have blue spark at the plug, plug is wet with fuel after several pulls when trying to start, has compression, but will not hit with fresh gas, ether or brake cleaner. I have tried starting with ether & brake cleaner both with carb (WB-12) on and with carb off (straight into cyclinder). Blew air through carb air hose. Strong stream of fuel from hose into carb when taking hose off of carb. I pulled carb, cleaned, installed standard Walbro rebuild parts but cannot get a single hit. I tried a different spark plug varified spark. How do you test quality of spark/magneto?
It appears to me that I have the big four: fuel, spark, air and compression. What am I missing?
