WANTED Early Husqvarna 357xp Piston
CJ Brown
7:28 AM
Belleville, Ontario, Canada
As the title says, I'm looking for a piston for an early 357xp. They used a narrower connecting rod/bearing in the early saws so the distance between the piston bosses is narrower (approx. 14mm). The later saws used a piston with approx. 15.5mm between the bosses. Anybody got anything before I go looking for a 257 piston?
Thanks,
Chris
Chief Cat Herder
6:28 AM
Thanks,
Chris
I had forgotten about this issue Chris. I have a 254 piston.....but nothing in 46mm.
CJ Brown
7:28 AM
Hi Randy. Yeah the early 357xps are a bit of a problem to rebuild. The guy I got the saw from straight gassed it and the dealer told him he couldn't get parts. So the owner bought a china kit (with the wrong piston) and installed it himself. That didn't go so well, so he sold the saw to me for parts. I have a cylinder here from another carcass but no piston.
CJ Brown
7:28 AM
Thanks J.J.. I am trying to avoid splitting but that is certainly an option. The bearings feel okay to me so I will try the piston route first.
I would have to fab up a splitter since these things have stuffers and yes, I am lazy lol.
CJ Brown
7:28 AM
Do you have a PN? I have a new OEM 47mm piston but I'm not sure on the boss width. I'll see if I can find it and measure but it may take a minute. I also should have a crank.
re: part number - Husqvarna 503920471
edit: The piston should be 46mm. 47mm would be for a 359
CJ Brown
7:28 AM
I am still looking for a piston.
In the mean time, I have order some shims/washers - some in S.S. and some in aluminum. When they get here I will see how they fit and if I think they might work I will post up my findings in a new thread in the chainsaw forum.
jacob j.
Lord of Cargo Pants
4:28 AM
Coastal Oregon
Chris - If you're gonna do the washer thing, I recommend getting thrust washers. Thrust washers are usually heat-treated and withstand the vibration.
CJ Brown
7:28 AM
Thanks J.J. - back to the drawing board lol. I will see what I can find
What if I heat treated the S.S. shims? In fact, if they are true shims, they may be quite hard to begin with - I would have to do a scratch test on them.
