Dolmar 9010
Jimmy in NC
7:48 AM
North Carolina
If you can avoid it, try not to take the brake system completely apart- it can be quite painful to get it all back together (there may be a servicing tool that makes the job much easier). Years ago, I did full side-by-side rebuilds on both a 9000 and a 9010, and the brake systems were the most difficult part. The oil pumps usually need going through as well but there is an oil pump rebuild kit available that contains the pump piston and all the fines.
OK you are a day late. I'm sure I'll manage to get it back together JJ.. anything else before I split it? May occur tonight if this 441C will get off the bench.
Adirondackstihl
7:48 AM
Upstate NY
I still hafta send you a pile of 420's for Heath.
Haven't forgot.
I need to reorganize and see if I can fit all that stuff in a single box. I'd rather not send the parts to you in the same tote it arrived in.
Shipping is gonna be costly either way.
Haven't had much play $ layin around to spend $70 on shipping.
Jimmy in NC
7:48 AM
North Carolina
Haven't forgot.
Her I sent 30 lbs of 056 mag 2 and o56 super today for just over $1.00/lb.
I can send a label if needed and you can drop off at a Fedex drop center.
Sent from my SM-G955U using Tapatalk
Adirondackstihl
7:48 AM
Upstate NY
That's a good idea Jimmy.
FedEx drop off is 30mi away.
Wife works in the same town. I could have her drop off.
Would probably be 2 weeks before I made it down there otherwise.
I'm trying to get a boat load of painting done before it gets real cold.
Jimmy in NC
7:48 AM
North Carolina
No rush.... I have a tractor barn to get built before frost...then a bunch of local saws for crews...then I'll give up and build demo saws.
Jimmy in NC
7:48 AM
North Carolina
In case anyone was wondering I am typing 1 handed holding my littlest. Her was to read "Jer" but auto correct doesn't like that.
Adirondackstihl
7:48 AM
Upstate NY
Just let me know when yer ready
