- 4:42 PM
- Aug 28, 2016
- VIRGINIA
Finally got time to work on my PS 9000. I knew it had bearing problems after I bought it a couple months ago. Well I have found that the crank was spinning in the bearing on the flywheel side, new bearing should fix that. Well not sure what to do on the pto side as the bearing has spun in the case. There is a little resistance putting the bearing in once in the pocket it moves all around. I was thinking of using bearing and sleeve retainer, Permatex #64000. But I have read on here about other products that may work better. @Chainsaw Jim. The bearing measures 1.575, the pocket measures 1.584 from front to back and 1.577 top to bottom. Any advice would be greatly appreciated.
Here is a pic of the bearing pushed toward the oil tank you can see the gap toward where the fuel tank would be.
