KUDOS Dolmar 7900 heated handle wiring
Shane¹
7:05 AM
Kentucky
Does anyone have a diagram of how the wiring goes on a 7900 heated handle saw? Got most of the heated pieces I think just got to figure out how it goes now
hacskaroly
2100 Fanclub Member
4:05 AM
Northern Idaho, Ehh
@Wilhelm do you have any information for this?
Not sure how close it is to a Husqvarna, but on my 272, it starts at the generator (behind the flywheel), the wire lead goes to the front handle and from there to the rear handle and then to the on/off switch. Other side of switch goes to ground.
I did find an IPL for a 7910 which has a the parts blow out for a heated handle, page 19, not sure how similar these saws are.
jacob j.
Only the weird
4:05 AM
Coastal Oregon
There should be some stanchions cast into the flywheel side of the case where the generator mounts for starting the wiring. It looks like the wire that runs to the switch/carburetor area goes with the spark plug lead for a ways which is routed in the air dam.
Shane¹
7:05 AM
Kentucky
I think I have it figured out thanks for all the help gentlemen! Goes from generator to switch, switch to tank heater, tank heater runs to top handle then top handle harness runs to ground by kill switch. Didn't realize there was 2 different cases for heated saws though so I have the generator mounted how I think it will work hopefully it doesn't explode into the flywheel
1:05 PM
No clue.
I have 2 "H" Dolmar's and don't use them. :rolleyes:
Also, neither is a large frame gal.
