Dolmar 64xx/73xx/79xx series, smurfs and solo 665/675/681 thread
5:20 PM
This thing is pretty impressive in hickory. It could be leaned another 1/4 turn on the H easy. Fixed another modded zama. Both needed complete clean and rebuilt. New throttle butterflies on both carbs.
When it breaks in good it should be even better[emoji51]
5:20 PM
Has the oiler been upgraded on the newer xx10 series dolmars?
No they still have the plastic bolt. The oiler is easy enough to disassemble and rebuild I’m not complaining though. The only ones I saw failed were on higher hour saws.
thedude74
Bonafide & Stuff !!!
3:20 PM
Alaska
So I forget, are the bar studs close enough together to run a Tsumura Stihl mount with only an adapter?
Probably. I've run a Stihl large mount on my 6401 without an adapter. It does look a little funny with the end of the bar sitting up due to the large slot and smaller studs...but it oiled fine.
dahmer
5:20 PM
Ellwood City, PA
mettee
3:20 PM
Arizona
I fired up the 7300 for my buddy. He brought me an MS180, MS291, MS290 to look over and fix.
I think the 7300 scared him, I don't think he is all about dat powa. And the MS291 either went lean or was straight gassed, he said he ran great right before it died.
He said how long is that blade, I said 28"
dahmer
5:20 PM
Ellwood City, PA
Those saws are gorgeous, I need one.
