Dolmar 64xx/73xx/79xx series, smurfs and solo 665/675/681 thread
dahmer
3:47 AM
Ellwood City, PA
I don’t recommend doing what I do lol. I always wear some sort of ppe logging. Not usually cutting cookies, I should. I just relaxed my standards.
You ain’t alone, we all do it. I had 4 36” diameter oak to noodle today, it was 91*, didn’t bother digging the chaps out. I’m older than you and should know better. We all do it.
3:47 AM
I will mention guys that I also had to replace the washer under the clutch drum in this saw, when they are worn out the chain will creep at idle more easily sometimes. I forget how much it is but its not an expensive part to buy. I had to do to it to some of the other ones I worked on too.
3:47 AM
I agree with ya I was being lazy today with the heat today too
3:47 AM
I wouldn’t run a 9 pin on these saws for work though. Beats on the clutch and pto bearing over time. Fine for play cookie cutting or testing though.
3:47 AM
What's the matter with the Dolly piston? Why the Stihl 046 piston?
Nothing really wrong with the oem piston. @mdavlee says the skirts are wider on the 46 piston and it is taller which allows him to port it differently if I understand right. Cons that I can think of are it requires a spacer and the piston is heavier. All I know is that this saw runs real nicely though.
3:47 AM
This thing is pretty impressive in hickory. It could be leaned another 1/4 turn on the H easy. Fixed another modded zama. Both needed complete clean and rebuilt. New throttle butterflies on both carbs.
