T.Roller
- 6:11 AM
- May 11, 2016
- Southeast, TN
That sounds like a better timeGlass of whiskey, tailgate, heckling...
Single malt?Some single barrel might inspire me to carve something Alabama related...
Maybe..
I keep studying this slabside piston, nice looking piece. The wrist pin is amazingly light looking. I wonder if it’s tapered? I believe the ring is a 1.2mm if I’m not mistaken, that surprised me too. Less friction than a 1.5
Thanks for the good info Bill, I was questioning what benefits a windowed piston would have in a bottom fed cylinder as well myself.My notes have the newer piston at 11.3 grams lighter (bare without wrist pins), not sure where I got that info.
Looks like the sides have a little more clearance than the windowed version around where it meets the lower transfers.
Not sure what use the windows would've had here in any case.
A little out of the norm to have a single 1.2mm ring...
CoolingThanks for the good info Bill, I was questioning what benefits a windowed piston would have in a bottom fed cylinder as well myself.
What if you could only pick 2?That sounds like a lot of work.
I’d rather sit on a tailgate and heckle..
Which one is this Jeff?Strong. I am giving it to Dan
It may also make it more free. If the base has less compression that phase of pumping would be easierThanks for the good info Bill, I was questioning what benefits a windowed piston would have in a bottom fed cylinder as well myself.
Yes. I bought it about a month back in CT. Paid $350 for it. Came with bar and everything. Seems to have a little extra uummph. Haven't really opened the covers.Which one is this Jeff?
Did it have too much power and scare you?
Fine line between performance, emissions and manufacturing processesVery interesting discussion. I am guessing they changed the piston for a reason. They probably spend a lot of $ on R/D, plus probably computer aided designs. I’m just trying to figure out that reason.
First I heard of bottom end issues on this platform.I also heard somewhere there were bottom end issues at some point so lighter piston and lower rev limit.
Most of those were due to stupid high compression and too much heat.First I heard of bottom end issues on this platform.
I know there were bottom end issues on the 5100S (spun bearings).
I’ve got the same wun! Or......maybe that’s mine? I gotta go check....
Well I'll take itYes. I bought it about a month back in CT. Paid $350 for it. Came with bar and everything. Seems to have a little extra uummph. Haven't really opened the covers.
I am just used to Stihl. I'll just give it away to someone.
