stihl livin
Do the Dallas
- 12:18 AM
- Dec 4, 2015
- Upper Midwest
It’s a clutch drum set up from a 5100-5105 and a washer. @fordf150 can set you up
thanks pat
And the 6100 uses the same clutch drum set up too. And get an Echo 590 clutch tool to. With a few swipes of a file or passes with a spinny thing it'll fit on Dolmar clutch and you'll save 60-70 bucks.thanks pat
89750516133What is the part number for the Echo clutch tool?
Which Dolmar models can it be made to fit?
A little off topic but do all the dolmars start as easy as the 420. I can pull mine slow as posible from cold and it starts crazy easy. I am quite impressednin how easy it starts.
I found written on a piece of paper that you need a 10x16x.2mm shim to run the 5100 drum
Anyone use .325 nk?
