- 11:46 PM
- Dec 3, 2015
- Banner Springs Tennessee
I have 044, 036 and 026 cases if you need measurements.
I'm having a member here do it for me...80x 7" pieces...ends drilled and tapped...plus the center holes drilled and tapped. Quite a job...by hand or otherwise lol.
just recieved the final taps today, so now I just gotta get on with the machining of the rods and sleeves and i'll start shipping out. so far 12 / 20 sets are spoken for.
I have made some plans, well, not sure if I nailed the big Huskies....
PTO all left handed threads. I sorted 362/365/371/372 away from 385/390 due I gone use a different socket (6202 vs 6203 bearing)
Tomorow plans is to check if I can get iron locally![]()
M10x1 m12x1.0 and m14x1.0....all left hand for the stihls.
It'll all be in the set![]()
I cant help you there my friend.Love to see a sheet like this for Stihl.
the threaded rods will have it all.... the adapter needs to be modded for the smaller stihls. but works as is for the 660 and the 880 (I think ...theoretically)
Tor, the way I look at your sheets. If a guy had the 346, 372 & 288 kits. That should just about cover everything Husky has.I cant help you there my friend.
I hope though that an Stihl guy will make a sheet for those Stihls, it make life easier when we make tools, but also easier when we use tools.
I put together two 550's last week, had already given away my 550 oem tool so I used the kit from 346 and 254.
Those are the kits I would had picked out also Brian.Tor, the way I look at your sheets. If a guy had the 346, 372 & 288 kits. That should just about cover everything Husky has.
What are your thoughts on them three?
Any other tools that you think are worth the price?
Yes Tor, I got the 550 kit already.Those are the kits I would had picked out also Brian.
You also has to get 254 or 357 kit, didnt you already had the 550 kit?
