Crank mounting tool - crank threads
Tor R
Novice, Leg model #2
12:30 PM
Mandal
One drawing to those who plan to make a couple sockets. Those two sockets cover pretty much all different cranks and bearings. Both sockets will put preasure on inner race only.
18.5 mm is because Husky use M18x1,5 threads for the nut, if you use 16mm bolts you will go for 16,5mm hole.
beaglebriar
The Peanut Gallery
6:30 AM
Warren Center, PA
I made another socket the other day for the 390/385. Same basic dimensions as the 372 socket but the OD on the small end is a shade over 28 mm vs. 27mm. I think it will work a little better for installing the seals.
Tor R
12:30 PM
Mandal
isnt those flywheel seals around 28mm in diameter?
Tor R
12:30 PM
Mandal
Yes they are. The socket that I made for the 372 is 27mm od and I wasn't comfortable pressing the 390 seals in with it.
got it, if I where to use the socket to knock in seals, 27mm is to little, but over 27mm gives to little distance to the crankarea where the seals are mounted.
Since you are into 385/390 nowadays, what dimension has the PTO crank? 17mm?
beaglebriar
The Peanut Gallery
6:30 AM
Warren Center, PA
Yes 17mm is correct.
backhoelover
I like tools
6:30 AM
lincolnton nc
i dont have a lathe :(. will one day :D. by then i will have bought all the husky crank and seal installer. their about 50.00 each give or take. and they make i think 30-35 different ones all together some are nla. i think i have 16 of them. the ones for the newer concrete saws come with 4 units that screw onto the crank i have used them on alot of other saws keeping me from having to buy other crank installers
Tor R
12:30 PM
Mandal
I think there is about 23-26 crank mounting tools, not included whatever came out the last 5 years.
What kits do you already own?
backhoelover
I like tools
6:30 AM
lincolnton nc
sorry you are right. i was looking at husqvarna tool boxes in my tool box and several of the husqvarna tools boxes where block off flanges. here are the tools manuals. i will have to look and write down the parts numbers. i have several that are nla that i bought from a retired tech
Mattyo
Youtube speciawist
6:30 AM
Farmington, CT
Thanks.....your research was pivotal here. So thank you!
Unfortunately ...as is...it won't cover the flywheel side for smaller stihls...because the seal pocket is too small. I'll work on it :)
Tor R
12:30 PM
Mandal
We are all here to share, end of the day some people improve our ideas. Well done work Matt.
Do you know the diameter of the seal and the crank axel diameter?
srcarr52
6:30 AM
Iowa City
@Mattyo I think you'll need another sleeve or a step down adapter for doing older Stihl saws with the tiny flywheel side seal, like the 044, 046, 064, and 066. I think their OD is smaller than the 3/4 all thread you are using, so the sleeve will need a step down and will have to be installed before threading the pull shaft onto the crank.
Mattyo
Youtube speciawist
6:30 AM
Farmington, CT
yep... i'm on it. I'm doing a run of these...20 tools / sets, and when they are gone i'll work on the next iteration I think I can keep the threaded rods the same, but use stepdown sleeve like ya say...but there is a tiny trick to it that i'm working on in my brain
the older 066 style is indeed smaller, but the new 660 barely makes it... and this was the limitation the current tool is designed to.
Mattyo
Youtube speciawist
6:30 AM
Farmington, CT
just recieved the final taps today, so now I just gotta get on with the machining of the rods and sleeves and i'll start shipping out. so far 12 / 20 sets are spoken for.
