Merkava_4
- 3:59 AM
- Jul 7, 2018
- Clovis, California
Craftsman Push Mower
Model: 907.388920
Serial: 112905M023952
Engine:10M902 0489 E2 05101754
Mower starts up on the first pull. Runs perfectly except for a series of muffled pops out the exhaust. The engine has never had this issue until this year.
This is the super simple Briggs & Stratton vertical shaft push mower engine with the Pulsa-Prime (tank mounted) plastic carburetor.
The first thing I did is change out the fuel pump diaphragm and matching gasket. The second thing I did is change out the primer bulb. That's usually all these carburetors need. After that I tried a different carburetor, different ignition coil, and different spark plug. No change in the misfire issue.
Right now I'm at a total loss. I don't know what to try next. I will try a brand new carburetor if you guys think that will solve the issue.
Model: 907.388920
