Compression Tester Hitting Top of Piston? Old Echo GTR-200R Curved Shaft Trimmer
cao-2000
OPE Member
10:20 PM
Julian, CA
I am diagnosing an old Echo GTR-200R Curved Shaft Trimmer for my neighbor.
I grabbed my compression tester, and I'll be darned if it doesn't seem to be hitting the top of the cylinder when it is screwed in all the way. So I grabbed a different compression tester, and same thing.
Is there a different (shorter) threaded piece I need for these smaller 2-stroke engines? Or maybe a different compression tester kit that might have it?
See photos for my current compression testers. One is an older generic, and the other is a new Lisle.
Thanks,
Chris
srcarr52
1:20 AM
Iowa City
Ditch the adapters and just use the threads on the end of the hose.
Duce
1:20 AM
Roscommon, MI
If those adapters do not have valve at it’s end, you will get low reading.
r7000
1:20 AM
CT
match the tester fitting to the spark plug, see how much of a distance difference there is.
you can back off the tester with whatever adapter fitting that's hitting the piston, a 1/2 turn or whatever until it doesn't hit the piston - open the tester valve so there's no compression to facilitate spinning the motor. Then wrap a little teflon tape on the tester fitting threads and don't screw all the way in only to the distance that seems appropriate, it'll seal well enough to get a good enough compression reading, just don't get the tape into the cylinder.
