peter92
- 12:11 PM
- May 19, 2016
- maryborough qld aust
noHeard good things about this oil.View attachment 55895
I have to ask. Should we start a oil thread?
1k hours is what I've read for stihl pistons. That's a lot of fuel through one.
I have always wondered about the life cycle of a saw in "Pro" hands. I understand that normally they are run over, crushed by a tree or flung off into the wilderness before the mechanicals actually fail, but assuming continued use with "normal" maintenance, can a "pro" get 1 calendar year of production cutting use on the same saw? 2 years? More? Obviously hours on the saw or "xx "board feet are the true measure.
Based the post above by @mdavlee, let's try something..
Assuming 6 hours of REAL saw run time per day and 1000 hour rating on the Stihl piston (we need to assume this 1000 hrs rating = optimal performance and not completely worn beyond use). We get 1000 hrs for piston /6 hours per day of use = 166.67 days of "optimal lifetime" from a Stihl piston. This is less than 1/2 calendar year.. does this make sense?![]()
It does make sense, but I would question the 6 hours of run time a day. There's a good amount of time riding from camp out to the cutting site, walking around, evaluating a tree, planning a fall, etc.
Even so, if you're using a saw every day to earn bread, a piston every 6-12 months isn't too bad.
I had a partner once who could consistently send 450-500 trees down the hill most days (I was doing a little over half that).
My eyes are boggling at that. That man was earning well!
He was a beast of a man- 6'3", about 265 pounds and strong as an ox. He ran 372s and 385s mostly with 32" bars. It was a bushel job, meaning we were paid for how much wood we could cut in a day. He consistently earned almost twice as much as I did.
That was years ago. He drives log truck now as a single owner/operator, and I work in an office.
I am pretty sure the epa hour rating ie 50hrs or 300hrs is a period of time OEM's are contractially obliged for the product to produce up to X amount of exhaust emmisions for the period stated on compliance plate. While it can be an indicator of engine build quality, it has not much to do with 'life expectancy' of engine, rather a period it will fit the regs at minimum.So in partial answer to the original question, pretty sure all ope sold in the u.s. Is given an epa "compliance period". While obviously not exact, it gives an idea of life expectancy under "normal use"
