ceramic bearings
sawtalk81
5:45 AM
California
looking for a builder to install a set of custom made solid ceramic bearings in a stihl case
8:45 AM
Is your saw race only?
Which model?
Full ceramic or metal inner/outer?
I’ve shifted away from them after hearing many negatives. I still have a dominant set here for Stihl.
sawtalk81
5:45 AM
California
yes race only 026 100% ceramic bearings thanks eric what size is your set?
8:45 AM
Mine are 036-046 sized. So the PTO would work, but not the Fly side.
8:45 AM
Yes, hybrid. Metal races with zircon balls.
sawtalk81
5:45 AM
California
can you tell me a way to stroke a 026 with some kind of top end mod?
Deets066
AKA Deetsey
8:45 AM
Is the saw stock now or worked over some?
sawtalk81
5:45 AM
California
its stock okay saw works got it would you know the specs to do such a thing
sawtalk81
5:45 AM
California
could i use a 024 bottom end o26 pro top end?
Deets066
AKA Deetsey
8:45 AM
Is there anything wrong with the bearings in the saw now?
Deets066
AKA Deetsey
8:45 AM
Nothing wrong with running the oem bearings. That’s what’s still in mine.
I run an 024 super with the piston milled flat, base cut about .050” and squish set accordingly. Big outlet out the front of muffler, timing advanced, and a modified WJ 69 carb.
sawtalk81
5:45 AM
California
thats a nice set up have you heard of any one doing a stroke 26?
sawtalk81
5:45 AM
California
can you do some digging around for me i can do a finders fee for the info spec so forth
Deets066
AKA Deetsey
8:45 AM
From the sounds of what Al said in your other thread. They would most likely have to be custom made.
