sawtalk81
- 9:00 AM
- Oct 28, 2019
- California
looking for a builder to install a set of custom made solid ceramic bearings in a stihl case
I don’t believe there is an easy way unless you send your crank to Crank Works. The 024 AV was able to be stroked with the 24 super or 026 crank I believe.can you tell me a way to stroke a 026 with some kind of top end mod?
From the sounds of what Al said in your other thread. They would most likely have to be custom made.can you do some digging around for me i can do a finders fee for the info spec so forth
