Carb adjustment tools
motoOzarks
motoMonster
12:59 PM
southwest Missouri Ozarks
Are kits like this worth it? Do they include useable tools? Work as intended?
As important; what tools do they leave out?
Hipa Pack-of-14 Carburetor Adjustment Tool Ignition Coil Spark Tester for 2-Cycle Small Engine Compatible with Poulan STIHL Echo Ryobi Troy Bilt Trimmer Leaf Blower Weedeater Chainsaw
Brand: Hipa
708 ratings
| 16 answered questions
Price: $21.98 & FREE Shipping on orders over $25.00 shipped by Amazon.
Get $10 off when you activate with Discover Cashback Bonus. Minimum purchase of $50. See terms.
  • Spark tester: Convenient to understand the operation of the ignition coil; White lettering makes it easy to read the gap measurement
  • Pack-of-14 carburetor adjustment tools: Must have for 2 Cycle engines to keep them in good performance
  • Compatible with ZAMA, Walbro, STIHL, Husq-varna, Craftsman, Poulan, Weedeater, Echo, Homelite, Ryobi, MTD, Troy-Bilt,Toro, Sears, Ruixing, Huayi; string trimmer, chainsaw, leaf blower, hedge trimmer, edger, pole pruner and anything else that utilizes the carburetor adjustment tools.
  • Squared handles, which makes it easy to tell 1/4 turn increments on the mixture settings when trying to tune a carburetor; Advanced heat treatment process and corrosion-resistant finish screwdriver bits
  • You will get: 14pcs carberator adjustment tool, 1 spark tester, 1 tool carrying case
SOS Ridgerider
Muffler Modded Member
1:59 PM
Central CT
Brand: Hipa
708 ratings
They’re definitely worth it. I have a couple kits like that, although mine are older and have maybe 8 pieces instead of 14. Haven’t found a carb I haven’t been able to adjust yet. You’ll honestly probably only use 4-6 of them anyways, but it’s nice to have around just in case.
nixon
1:59 PM
West Sunbury ,Pa.
They are worth it . You asked what they left out ... limiter removal tools .
Basically 2.5 mm ,and 3 mm LH threaded tools with a handle .
IIRC DDave at Chainsaw Conservation has them . They make removing the limiters easy ,without buggering them up .
BangBang77
12:59 PM
Oklahoma
If you work on anything other than Stihl, yes, they are definitely worth it. You will need these tools with various Dolmar/Makita and Husqvarna ope. Not sure about Echo stuff as I've never worked on them.
My set gets used more often than I thought when purchasing them.
motoOzarks
motoMonster
12:59 PM
Super duper
I'm surprised there is not a sticky with all kinda tools in it already..........
Do it cause you want to don't do it for me
7:59 PM
I got this kit off eBay, works fine , quality is good
av8or3
1:59 PM
Waleska,Ga.
motoOzarks
motoMonster
12:59 PM
Stihl numbers of adjustment tools
 5910 890 4502  5910 890 4501  5910 890 4500  5910 890 2310  5910 890 2307  5910 890 2306  5910 890 2305  5910 890 2304
ryan a
1:59 PM
Philadelphia,pa
Anyone have a recommendation for Echo carb adjustment tool? There has to be something better than the generic, small/flat screwdriver for my 620p.
Thanks
