- 6:46 AM
- Jan 24, 2018
- Extreme Southeast CA
On a USG, that inside angle is all the tilt of the wheel…they were ground with the same settings, I’ll try more aggressive. The only difference I can see is the C1 is thicker material all around. Also when filing it, it left a weird gullet hanging out to the outside…going deeper on the grinder got it out but it still doesn’t cut. I’ll have to find the other loops and try different stuff on the grinder. Probably end up saving them for finishing cuts where I hit nails. They are 24”. Have been running them on 266/670. Maybe grind them aggressive and put them on the ported 7900 with an 8 pin. That should make them eat.On second look the cutter in the front has a more blunt profile compared to the cutter in the rear..differences between the shape of the back of the cutters between manufacturers will sit different when indexed by the tooth advance arm..having a more forward or rearward positioning in relation to the wheel will do this.
Then he will never be the same again.if you want you can send it to me and i will grind it square. then see if it cuts
I have some square by the famed @Armbru84, I know…Then he will never be the same again.
