HELP! Brown rot on peaches
ErnieG
6:15 AM
Northeast PA
So this is the second year in a row I'm gonna loose all my peaches to Brown rot and it's got me sick !
I've been reading up on this and it seems treatment is all over the place .
Is there any hope for this season and
does anyone have experience with this fungus and a good treatment method for the next growing season for me ?
Thanks very much
Ernie
JimG.
6:15 AM
NorthCountry
For me in NY state I would call the local Cornell cooperative extension grow line. Are there any nurseries or orchards in your area?
Coupe
10:15 PM
New Zealand
Have had problems with brown rot myself that is here in New Zealand and it
is very hard to get rid of because it get's in the soil around the tree as well.
We hade a dwarf peach and ended up pulling it out and putting a lemonade
citrus tree in it's place.
All I can tell you is any pruning bits take well away from the tree and burn them
as it is very contagious and if you go on the internet it will tell you to remove all
infected twigs,gummy cankers as well as mummified fruit. But when you spray the tree you
have to spray the ground around it as well. If you don't like using spray my advice would be pull
the tree out and plant something else.
Coupe
10:15 PM
New Zealand
Brown Rot​
Monilinia laxa and Monilinia fructigena. Brown Rot is very common in the Auckland region, fruit is more susceptible to infection when the weather is humid.
Brown Rot is a fungal disease that most commonly affects stone fruit, particularly peaches and nectarines. It enters the fruit through bruises or damaged areas, which can cause fruit to fully rot within days and remain on the tree while shedding their spores until eventually becoming mummified.
It is recognisable by the distinctive brown pustules that form on the fruit, which then slowly rot on the tree. If the fruit is picked in the early stage of infection some of it may still be able to be eaten.
Spring is usually when infection starts, which can turn blossoms brown. It only takes a few infected flowers to infect a whole tree as the fungus produces millions of spores which are spread by rain and wind.
Prevention​
To reduce the chances of brown rot badly affecting trees, keep trees healthy and well-fed. When pruning, prune to an open vase shape to allow more air to flow between the branches. When planting new trees allow plenty of space between the trees.
Thin out fruit as it is produced, clusters of fruit set close together will provide an ideal situations for Brown Rot to flourish.
Remove any infected fruit off the tree and the ground as soon as it is seen to avoid the spread of spores.
Treatment​
Spray with Yates Copper Oxychloride at petal fall and at 3-4 weekly intervals until harvest.
When using sprays and chemicals always read the label and follow instructions carefully. Spray in the evening to avoid harming beneficial insects.
Coupe
10:15 PM
New Zealand
Brown rot is a devastating fungal disease caused by Monilinia fructicola that affects peaches and other stone fruits, leading to blossom blight, twig cankers, and a rapid rot of mature fruit. It overwinters in mummified fruit on the ground or tree and in infected twigs. Management involves sanitation (removing mummified fruit and pruning infected branches), proper air circulation, and a consistent program of fungicides, especially during bloom and in the weeks before harvest.
What is Brown Rot?
  • Cause: The fungal pathogen Monilinia fructicola.
  • Affected Parts: Blossoms, fruit, twigs, and spurs.
  • Symptoms:
    • Blossom Blight: Flowers wilt, turn brown, and develop a dusty fungal growth.
    • Twig Blight/Cankers: A gummy canker forms on the twig, potentially leading to dieback.
    • Fruit Rot: Small, brown spots appear on fruit that quickly spread, covering the entire fruit in a few days with a fuzzy, grayish spore mass.
How it Spreads
  • Overwintering:
    The fungus survives the winter in mummified (shriveled) fruit on the tree or ground and in infected cankers on twigs.
  • Spring Infection:
    Spores are released from overwintering sites in the spring and infect new blossoms.
  • Spread:
    Rain, wind, and insects spread spores from infected blossoms and mummified fruit to other parts of the tree and to other trees.
Favorable Conditions
  • Weather: Warm, wet, and humid conditions during bloom and ripening.
  • Fruit Injury: Cracks, bird damage, or cold damage on the fruit make it more susceptible to infection.
Management Strategies
  • Sanitation:
    • Remove Infected Material: Collect and destroy all mummified fruit (on the tree and on the ground) and diseased twigs.
    • Cleanliness: Clear away fallen fruit from under the trees.
    • Pruning: Thin out the tree canopy with pruning to improve air circulation and allow sunlight penetration, which discourages the fungus.
    • Site Selection: Choose orchard locations with good air movement and high elevation.
https://plantdoctor.co.nz/problem-finder/brown-rot/
ErnieG
6:15 AM
Northeast PA
What is Brown Rot?
  • Symptoms:
How it Spreads
  • Overwintering:
  • Spring Infection:
  • Spread:
  • Sanitation:
Thank you for all the info !
Ernie
Nutball
5:15 AM
Mt. Juliet, TN
It is possible to get some peaches. I used to always loose my peaches to rot, then one year I got a few that didn't while 95% did rot, and this without any spraying. The tree died the next year. I don't know why, but it may have been from me pruning it during the warm season and letting it get infected with something through the cuts.
Stihl036
3% Neanderthal
6:15 AM
It ain't got no gas in it.
It's my understanding that peach growers follow a spray schedule that is determined by monitored insect and disease emergent times and usually get notices by gov. ag. agencies, etc. Maybe six to eight sprayings per season with large machines with fans to move lots of air.
