Briggs and Stratton help
Ed Prater
OPE Member
10:42 PM
Botkins, Ohio
A friend of mine came over and did a leak down test, and he said it was in bad need of piston rings, so we will give it a shot.
Lone Wolf
10:42 PM
Nj
I put oil in the cylinder ,a few squirts with a can, and if it comes up on the compression test its the rings, if the same compression then its a valve.
Fish
10:42 PM
Manton Ky.
If it showed 80 psi on a compression gauge, it would at least hit. Stop before you sink a fortune in it, and start over, and respond to some questions.
Fish
10:42 PM
Manton Ky.
Can you take some pics as well as respond to some questions?
Fish
10:42 PM
Manton Ky.
First pic, take off the head and the starter, and put up some good pics at tdc.
Ed Prater
OPE Member
10:42 PM
Botkins, Ohio
Fish, I was trying to get this to run for a friend of mine, he came and picked it up Saturday, but I will forward this information to him, and will let you know what happens, thank you for the comments. Ed
Fish
10:42 PM
Manton Ky.
My guess, is that your engine just had bad gas/water in it initially, which is why it wouldn't even pop. I am also guessing that the flywheel key was fine when you looked at it, but sheered soon after due to insufficient torque on the flywheel nut or starter clutch, which is a common thing to happen. But being far away on the internet, these are just guesses, which is why I was requesting the pics and info.
I do not think new rings will help whatever this problem is.
Lone Wolf
10:42 PM
Nj
Well how did this go ?
icefire
OPE Member
8:42 PM
diamondville
I am working on a horizontal engine model 136212, type 0026-01, it has 80 psi compression, has good spark, and a new plug, and it is wet, flywheel key is not sheared, I watched both valves open and close, I spray carb cleaner in the carb and cannot even get a pop, I am baffled and need some guidance, please.. thanks Ed..
are the valves closing all the way?
