Bridge ports
Your best guess
  • Do they work?
    Votes: 4 26.7%
  • Have you tested them?
    Votes: 3 20.0%
  • Will I be banned?
    Votes: 8 53.3%
  • Total voters
    15
Keith Gandy
Maxima K2 40:1 87 Pump Gas
5:22 AM
Provencal, Louisiana
Seat of the pants feel?
It all boils down to how the saw runs when I put it in my hands in the end and if it cuts like I like. Seat of the pants feel. Sound can be deceiving though. Example is when I ported my 241c and ran it beside a Snellerized 346xp and the 346 screamed and I never thought the 241 would be close as the 241 didnt have the rpm of the 346. After video of both and averaging 4 cuts the 241 was a tad faster in 12" wood
concretegrazer
5:22 AM
Mo
Same chain?
paragonbuilder
6:22 AM
Norwich, CT
Problem with quantifying results is that you can't assume they're most effective using the same build parameters as without them. Maybe bridge ports work best with more/less blowdown or different transfer entry angles or...
[emoji106]
I think it was tree monkey that said if you are getting gains from bridges or fingers than your transfers could be better.
I see it as a different way to get the same result.
concretegrazer
5:22 AM
Mo
Suprised me lol!! That NE 346xp was screaming and has an 8cc advantage over that 42cc 241
Of course it was screaming. It wasn't cutting. Your comparing a clogged up semichisle to the best 3/8 lp. Run some PS or full size 3/8 on that 346 and see what happens.
concretegrazer
5:22 AM
Mo
Lpx is chisel.
Edit....
Bpx is semi & this is in .325.
