Boogered thread on Husqvarna 2100 crankshaft
Mark71gtx
9:07 AM
Fuquay Varina, NC
Haven't posted in a while. Been on a shutdown and haven't had much time. I plan on getting back to my 2100 project soon. The main problem I am having with it right now is the crankshaft threads are stripped. Do I need to split the case ( has not long been put together with all new bearings and seals) and replace the crank, or can I reasonably rethread it? If I can rethread it, what size would you all recommend? Thanks!
"Edit" flywheel side... It matters, lol...
Homemade
9:07 AM
Wisconsin
When you say stripped... how bad? Sometimes you can "chase" the threads and have it hold with same sized hardware. Especially being flywheel side, there isn't a ton of force like the clutch side. But if there is no threads left, then a new crank is my suggestion. To get new threads on the remaining material, it will have to be lathed true and undersized.
Mark71gtx
9:07 AM
Fuquay Varina, NC
Thanks for the input so far guys. I will try to get some pics soon. Not too much home time lately.
Lone Wolf
9:07 AM
Nj
Mark71gtx
9:07 AM
Fuquay Varina, NC
From my recollection there was not much of a thread there to start with and the nut was completely shot to boot...
Homemade
9:07 AM
Wisconsin
How did this happen?
