HELP! Big cylinder bolt spacing measurements
Shane¹
4:35 AM
Kentucky
Anyone have any of the big cylinders laying around for some bolt spacing measurements I am planning a potential hybrid mission but need some info on where to start on a cylinder. I am thinking if anyone has 084, 088, 3120, or even an 066 or 395 cylinder laying around those would be my first options. If anyone knows of any other bigger cylinders let me know of those too. Maybe even a 390xp
Powerstroke Cowboy
2:35 AM
Montana
Nice thanks!
Stihl ms660 base bolt pattern, dimensions pulled from a cylinder.
I thought I had an extra 880 base gasket laying around, but I don't. I'd have to pull the cylinder off the 880 to grab dimensions. Sorry about that.
Edit, changed wording to make it easier to find for anyone searching the web for the dimensions.
Shane¹
4:35 AM
Kentucky
660 base bolt pattern pulled from a cylinder.
Thank you very much don't worry about the 880 i am sure someone will have an 880 cylinder kicking around
Shane¹
4:35 AM
Kentucky
Anyone have an 088 or 084 cylinder kicking around they could measure for me those two are the ones I am curious about the most
Shane¹
4:35 AM
Kentucky
The 395 I heard was a lot of work same with 084 and 088 just wonder which one might be better but then solid runner could be just 066 would be a pretty good bump in displacement
srcarr52
4:35 AM
Iowa City
I had to deck the case 0.100" to get the 395 cylinder to work as I didn't want the mounting flange to get too thin.
