Best 545mk1 built?
kårekloak
2:51 PM
Norway
Have an untouched 545mk1 I want ported. I do also have a box with 550 mk1 parts I can use on the 545 if needed. What will be the best combo when using the 545 case to get the best working saw? Cylinder/coil/carb?
Ford3000
1:51 PM
@huskihl or any of the builders, can you help here, thanks.
Dolkitafreak
Dolkita686
9:51 AM
Central Ohio
I get mixed up in the 5 series. The xp models all have a semi-pro counterpart but they don’t all have the differences.
The 550 likely has stuffers and possibly larger transfer caps.
@Dolkitafreak might know
545 vs 550 in mark one flavor the difference is stuffers and rev-boost. Cylinders are identical.
