Bar options between 42"-50"?
Marshy
WFO Cutting
10:52 AM
Mexico NY
Guys, what bars options are there in D009 mount, 3/8 pitch, 0.063 gauge between 42" and 50"?
I'm thinking about getting into a 48" Alaskan mill and was trying to find out if there is a bar in between the 42 and 50 inch bars...
mdavlee
Hillbilly grinder
10:52 AM
TN
44" GB. Some were made for helper handles.
Derf
10:52 AM
Long Island NY
Forester has some larger size ones, as does Oregon I think. In D009 you might have more luck with 0.058 than 0.063.
Marshy
WFO Cutting
10:52 AM
Mexico NY
The 0.063 isn't a must. My 36" bas is 63 and I thought it would be good to keep the wider gauge for milling but if only 58 was available that would be fine. I've searched Oregon and it seems like they only have 42/50...
mdavlee
Hillbilly grinder
10:52 AM
TN
63 lets you run semi skip chisel chain if you have a powerhead to pull it. 58 options in chain suck
Marshy
WFO Cutting
10:52 AM
Mexico NY
I have a stock 298 and some 2100's.
junkman
Crush it
7:52 AM
pacific northwest
I would recommend .404 .063 on a bar that long for the better oiling and less stretch .A 42 inch works good on my 36 inch mill if that helps for sizing ,you lose some bar on both ends from the clamping points .
Marshy
WFO Cutting
10:52 AM
Mexico NY
I have a log that's all of 40" so I was hoping to get a bar about 44-48". The mill will be able to do a 48" cut but I believe I'll start to get power limited with that large of a cut.
