Axes for Wedging
Which do you think is best?
  • Sledgehammer
    Votes: 4 17.4%
  • Axe
    Votes: 3 13.0%
  • 3 lbs
    Votes: 1 4.3%
  • 3.5 lbs
    Votes: 3 13.0%
  • 4 lbs
    Votes: 5 21.7%
  • 4.5 lbs
    Votes: 2 8.7%
  • 5 lbs
    Votes: 9 39.1%
  • 5.5 lbs
    Votes: 1 4.3%
  • 8 lbs
    Votes: 2 8.7%
  • 10 lbs
    Votes: 0 0.0%
  • Total voters
    23
michaelmj11
11:45 PM
Starkville, MS, 39759, USA
I do not know how many folks have make it over here from AS, but I wanted to continue the conversation that had started up about which axe(s) you folks think best for driving wedges, and also being able to get yourself out of a pinch.
12:45 AM
5 lb council
michaelmj11
11:45 PM
Here is my Frankensteined creation (it started with a Hudson Bay Council Tool axe, and a piece of bar stock steel):
So it is now a 5 lbs council tool, that is just about perfectly balanced (that picture took FOREVER to get right)
I've only tested it out once but really liked the result.
Gunn
Yay sawz
11:45 PM
Plover wi
I just noticed the picture with the scale, it looks like the head is loosening up on you? Or was that before you finished hanging it?
P.M.P.
Stiff Member
12:45 AM
Michigan
I voted 5 lb because its all I ever used.
michaelmj11
11:45 PM
It loosened when I first got the axe and tested it out, so I got it to come all the way off for the welding. And when I put the handle back on, when driving the metal and wood wedge home it kept creeping up like that, so I drove an extra metal wedge and them threw in some JB weld for good measure.......
I'm not overly fond of wooden handles (one reason I had the bar stock overlap the the handle ;)). I have never had much luck with the wooden handles. I've already started looking for a fiberglass replacement handle.
12:45 AM
I would like to have a 6 lb Collins if I could find one. Then a nice 3.5 lb felling axe.
WOODS
12:45 AM
UETN
Don't think you can beat an old school raft pattern axe. 4 pounders seem rarer than 5 pounders. Plumbs seem to have fared better over the years than Collins and other brands based on eBay listings.
Ron
WOODS
12:45 AM
UETN
Newer Collins: Duplicate post deleted.
Ron
12:45 AM
Those look nice Ron.
WOODS
12:45 AM
UETN
I like them because the poll is designed for driving. Unfortunately it looks like others are taking a liking to them as well as the prices seem to be getting higher. Ron
michaelmj11
11:45 PM
I would love to get just the handle off of this axe to use with my modified one, but unfortunately I think the Garant one is a solid axe-head-and-neck.
http://www.garant.com/html/en/produits/produit.php?idProduit=1003355&typeProduit=recherche
And failing that find/get this handle BUT in a 28" (except they sell this sort of handle Only already attached to an axe head.... unless you want the 34" replacement handle.....) so I need to see if I can contact the manufacturer for more information.
http://www.garant.com/html/en/produits/produit.php?idProduit=1000661&typeProduit=famille
madhatte
It's The Water
9:45 PM
Puget Sound
I have a couple of 4 pounders and a 5 pounder; I use the 4 pounders more because I'm more willing to carry them. That said, the 5 pounder definitely hits harder and lifts more per whack.
