Fish
- 2:26 AM
- Jan 18, 2016
- Manton Ky.
Fish, I just thought of something. That impulse hose line is probably OK and intact. Now that I took the saw almost apart, I see nothing wrong with the hose. The real problem is that the engine is not delivering the impulse through the hose that the carb needs. The rings may have a separation problem, but who knows what's causing the lost impulse?Yeah, I wouldn't have bothered with all of the pics, if I knew those chitheads were going to delete them.
I'll do that as soon as I get it all apart. I'm committed to rebuilding it now. This saw has quite a few hours on it and nowadays you can get piston and cylinder kits for half the price of what Stihl used to want for them.Yeah, I've run saws with the impulse line disconnected, and they never have resembled your problem. And I never really rely on a compression gauge for much. I only have one for the pic I put in my E-bay auction, on the rare times that I sell a whole saw.
Can you put up a pic of the piston/rings through the exhaust port? Also take a pic of the piston on the intake side.
I actually checked the impulse hose line again after I removed the handle and shroud. I dabbed the grease right on the end of the hose and still had no impulse movement of the grease, spark plug in or out. There also is no crack or defect anywhere on the hose. This is really an unusual sequence of events.On this saw you won't feel any impulse at the hole in the boot because the boot pulls away from the handle assy when the carb is removed, and any impulse leaks out around the boot flange. So you may have impulse even though it seems like you don't.
Also you can change the impulse hose without pulling the handle... just reach in there with long needle nose pliers where the hose connects to the cylinder.
I just bought a MS250 p/c kit from HL on special for $17. Quality looks good and compression is 165!
I've never had an impulse hose blocked either. By process of elimination, there is virtually nothing left that could be causing this failure to start.I've never had a saw where the impulse hose/system was "blocked" but I guess anything's possible.
So you're replacing the cylinder/piston without confirming there's something wrong with it? That's pretty extreme shotgunning.
Vac/pressure test performed?
A 20min pressure/vac test would answer a lot of questions.
Pressure/Vac test should tell you something
Sounds like a plan StanAt this point, I discovered a bad crank shaft oil seal on the clutch side, totally in pieces. That let in air and probably disengaged the impulse hose completely. That in turn made it impossible for the the carb to deliver any fuel mixture to the cylinder.
So, if I replace the crankshaft oil seals (might as well do both of them), I might be in the clear and this saw's engine may yet run again. Seem reasonable? WDYT?
Plan and mission accomplished! I replaced both seals after tearing the saw down almost to the wire. Then I carefully reassembled everything with the new seals in place, resealing the clam shell. Compression still measured 145 psi.Sounds like a plan Stan
