Stihlsmoking
City Hillbilly
- 3:34 AM
- Feb 29, 2016
- Cincy
Kinda what I thought. Then I was thinking the air leak is not that bad cold but after heating up it's probably a lot worse ?jeremy that helicoil looks like *s-word and should be a solid insert not just the wire type
The one he had didn't so I tried one with seal still leaked ? Think I'm just going to try a solid insert and retest ? I've had good luck with them.I've used those wire type a million times and have never had a problem.
Does the plug have the gasket on it? That's where it would seal.
Spark plug threads always seem to leak at least a little bi.
The 'gasket' is there for heat transfer.
Back in the old days, plugs came with a dead soft copper gasket. They sealed good.
Is it common for them to leak ? I couldn't find a leak elsewhere? ThanksThat helicoil is original to that cylinder.
All the older STIHL cylinders had them.
