Adjust Carb Little Echo
hotajax
12:00 PM
Eastern PA
OK, time for y'all to laugh at me. I have a little limber, needs to feather the throttle to get it to rev. If I don't feather it, it will stall. Do I need more air or more fuel?
Thanks.
Ford3000
5:00 PM
Screw out the L screw a little at a time, but make sure your saw engine is warm first, it will hesitate a little when cold, that is ok, as long as the hesitation is gone when the engine is up to working temperature. When you screw the L out you might find the engine will die out when it returns to idle, if so, then screw the idle screw in to bring up the revs, you can do this with the engine off, but best done when the engine is running as you can set it to where the chain is not moving when at idle.
Ford3000
5:00 PM
Make sure the spark screen is clean, that will cause running issues too.
hotajax
12:00 PM
Eastern PA
No, it is a small limbing saw. I forget the number. Wife bot it because she thot it looked cute. Go figure. I start it up for her and she goes out and cuts off her ankles.:p
It's an Echo 330. Just remembered
hotajax
12:00 PM
Eastern PA
Top handle. Probably 15 years old and runs everytime. Echo is great.
hotajax
12:00 PM
Eastern PA
Top handle or rear handle, what age of a saw is it.
Top handle. Will try some new homebrew 2 cycle fuel that I just mixed up a few weeks ago and see if it makes any difference. Some e-free in 40:1 with Marvel Mystery Oil in the recipe. That stuff does some serious cleaning.
