Accelerator Pump O-Rings (Carburetor Model Look-Up)
Vintage Engine Repairs
8:45 AM
australia
@Vintage Engine Repairs Just curious where you got your o-ring dimensions from? Did you measure samples or find actual documentation for the sizes?
I think that your m2.3x0.8 might actually be 3/32" x 1/32" imperial (.094" x .031").
I am getting ready to order some wher the shipping is likely equal to or greater than the cost of the parts and want to be sure I get the right sizes.
There is no documentation on these sizes, no.
I discovered it through comparing part numbers to dimensions. So far they have all been metric - expected as they’re a German company.
Example: 195503010 is a 3x1 metric o/ring
You take the last 4 digits
195503010 = 3.0 x 1.0
19550
3510 = 3.5 x 1.0
19570
2308 = 2.3 x 0.8
OILER]ISPOILER]
This is a common numerical ordering system making P/O very efficient to fill out.
Once I figured out that was the likely means to decipher the size, I measured the bore, piston groove and checked o-ring clearance charts and confirmed it on a bunch of different carbs with accelerator pumps.
Wonkydonkey
Plastic member
1:45 AM
Sussex, UK.
I also took a 250 carb (C1Q S91A) & a 200t carb (C1Q 61 )apart the other day.
It was a strange looking at the small differences. I'm guessing less fuel being pumped due to the bigger sized pump in the 250 ? Although I could be wrong 🤔
Anyway the 200 carb pump an oring pics
Wonkydonkey
Plastic member
1:45 AM
Sussex, UK.
And the 250 carb pump , same oring just a longer piston .
I didn’t measure the springs, 🤦‍♂️, they seemed to be slightly different in lengths , I guess I should have measured the Recess in the pump.
I could always pull them apart and get those sizes as I’ve yet to get the orings.
Wonkydonkey
Plastic member
1:45 AM
Sussex, UK.
I just realised I didn’t post the 200carb pump length . it’s got a different top shape, would This give it more movement ? By the throttle butterfly cam.
I will Investigate more when I get the orings.
SteveSr
8:45 PM
North Carolina
...However just like a lot of things you have to research it .Just remember "google " is your friend .
I have been looking at several manufacturers. One of them, Marco Rubber, says that regular nitrile/buna-n is NOT recommended for fuel applications! Huh? Well apparently there are several varieties of Buna-n. One is hydrogenated which is rated for fuel use. I doubt that Ebay / Amazon can tell you which compound you are buying.
I am also considering FKM or similar compound which is flourocarbon (think teflon) based.
SteveSr
8:45 PM
North Carolina
Those are Zama part numbers not Stihl. I didn't think that Zama was a German company.
19550
3510 = 3.5 x 1.0
19570
2308 = 2.3 x 0.8
Great detective work! Unfortunately the 2.3 x 0.8 is smaller than standard sizes. The smallest that I have found is the 3.0 x 1.0. I think that I have some of the smallest size directly from Stihl. Unfortunately they don't fit the carb that I am currently working on.
8:45 AM
australia
Yes you’re quite right mate, my apologies, but either way, yes they’re all metric that I’ve found. Try Amazon, thats where I get mine. From memory I paid $10 Australian for 20? They’re good too!
SteveSr
8:45 PM
North Carolina
Just for grins you might want to take a sample from each lot and soak them in petrol for a month or so and see if they change size or stiffness.
el33t
2:45 AM
Poland
The ZAMA companies are owned 100% by Stihl. But it doesn't matter about o-ring sizes etc., because even if they weren't, the whole world generally uses the metric system anyway. Even the U.S. auto industry switched to it back in the 1970s and 1980s. If even some dimensions are derived from the imperial units, they are expressed in millimeters (for example) on technical drawings and in published international standards.
Besides, the length of an inch was standardized in the 1950s defined in relation to the meter.
8:45 AM
australia
Yeah I could do that. The supplier I use is the same one that sells them in the states so it may be handy. Though I have used a number of them with no returns so far so I guess that says it all :)
EFSM
7:45 PM
Extreme southern IL
19550
3510 = 3.5 x 1.0
19570
2308 = 2.3 x 0.8
OILER]ISPOILER]
I guess those sizes are ID and thickness of the o-rings? That makes a lot of sense that those are the dimensions.
Wonkydonkey
Plastic member
1:45 AM
Sussex, UK.
I thought I,d add this here, as I’ve fixed the oem carbs piston pump with the help of this thread. 👍 cheers Tom, 😉
Wonkydonkey
Plastic member
1:45 AM
Sussex, UK.
I got a “Viton” oring fkm iirc. As I know these are better suited for fuels/oils , I will see how it lasts.
I know buying here in the uk from a uk seller isn’t cheap due to postage etc. but I’ve got some more coming from China 🤔
SteveSr
8:45 PM
North Carolina
8:45 AM
australia
G
Good work mate!
