Poleman
- 7:26 AM
- Jan 18, 2016
- Rapid City,S.D.
That's correct Randy. That way you can always go back to correct crank/flywheel set as original. The big thing to me is the little crank mark for TDC an the noted location. The flywheel can be positioned from there. Even removing the flywheel after mod just set the crank for TDC and reposition flywheel to desired location again.
