620p delayed chain brake
Kerfed
2:23 PM
Maine
Sporadically has a delay before the brake engages when saw is at idle. Hit the handle…1-2 seconds later…brake is on. Thoughts?
EFSM
1:23 PM
Extreme southern IL
Check to see if it does this with the side cover off. I've sometimes had to grind/sand off some of the travel limiter flange on the right brake flag mount where it hits the top of the side cover. Even on a new unit they sometimes have a delay because the brake lever can't move front far enough. Try grinding some off the flat portion on the bottom of the brake mount and see if it improves things.
Kerfed
2:23 PM
Maine
Will do that sounds likely. It’s annoyingly sporadic, worked flawlessly for months then started again.
