el33t
- 4:24 PM
- Aug 28, 2024
- Poland
Well in Australia Stihl oil is made by castrol just like pretty much all Stihl oil outside the USA, not quite sure why Stihl has opti blend the oil in the states but they do vs having castrol make all of it. Husky xp in the USA was made by Phillips 66 and was an fd rated full synthetic oil.
You will be hard pressed to find a fully synthetic oil. Those marketed as such also contain Group 2 or 1 oils, for example. Here is an example taken from Husqvarna XP+ and XP SDS.
XP+:
XP:
CAS 64742-54-7, CAS 64742-47-8, CAS 64742-65-0 are Group 2 oils. CAS 64742-46-7 is Group 1 oil. From the ingredients list, it appears that an oil that can be described as synthetic (regardless of court rulings) is at most around 30%. Anyway, Husqvarna refers to their oils as a 'synthetic blend'. This is also true of other oils from well-known companies. Nothing wrong with that. The most important thing is how the oil performs in practice in a specific application.
