FOUND IT 562xp Gas tank
Jts trikes
6:11 PM
Indiana
Sheared the key on my 2013 562 xp flywheel. Looking for a replacement.
srcarr52
6:11 PM
Iowa City
The key is only for installation indexing, it's not required to keep the flywheel in place. Carefully line them up and reinstall the flywheel.
Jts trikes
6:11 PM
Indiana
Thanks! I did try that and it is running, but i didn’t know if it was a good long term fix. I guess I’ll just run it then. Thanks again.
Jts trikes
6:11 PM
Indiana
Reviving this thread.
I am now looking for a gas tank for my 562xp.
It doesn’t need to be pretty.
Mine is leaking.
Duce
6:11 PM
Roscommon, MI
Mine is leaking.
Where is it leaking? Could you weld it together with soldering iron.
Jts trikes
6:11 PM
Indiana
It’s leaking around the sight gauge.
I tried welding it there but no success....
Duce
6:11 PM
Roscommon, MI
I have sealed one with an HDPE glue before, do not remember name, but found it at true value. High density polyethylene.
CIAmike11
6:11 PM
Adirondacks, NY
I got about half a dozen bonenyard OE 562’s if they issue re occurs brother
