HUSQVARNA 55 Rancher
Burchie70
1:35 PM
New York
I have a Husqvarna 55 Rancher EPA I believe it’s 2003 and I need to order some parts for it. I checked the compression and it’s at 170 psi but it runs rough. I want to order a carb rebuild kit, spark plug, gas line and fuel filter. I also have a couple anti vibe mounts I should change. My question, where is good place to order Husqvarna parts that are reasonably priced ?
Thanks for any help
USMC615
Fapper Fi
1:35 PM
Mid-Georgia
See that ‘Husqvarna OEM Parts’ ad in the top center of the forum home page...click on it.
Burchie70
1:35 PM
New York
I have another question as I’m looking at parts diagrams. What’s the difference with the numbers for 55 rancher epa? Example 1998-08, 2006-02, 2007-02, 2000-05, 2004-01 ?
CJ Brown
1:35 PM
Belleville, Ontario, Canada
This page should provide all the parts lists you need for your 2003 55 Rancher EPA
Be aware that sometimes the numbers in the price list don't correspond to the numbers on the parts diagram because some parts have been superceded over the years. You will figure it out.
https://www.firedog.com/catalog/husqvarna/chain-saw/55-rancher-epa-2000-05
Gizzard
1:35 PM
KY
The 1998-08 would be current parts list for Rancher's built August of 1998. I usually pick parts list that is closest or just prior to build date of saw that working on.
5155
1:35 PM
pa
The plastic intake partition,
intake manifold boot,
and impulse grommet
Are highly replaced items also.
Babysit the female threads on the plastic partition.
