55 presence lever spring
5155
9:09 PM
pa
I want to take it from one and put into another saw,
I removed upper roll pin and the little side plates on throttle handle.
Do I need to remove anything else to retrieve that spring?
As in the lever itself or another pin?
Seems a tricky little thing.
Duce
9:09 PM
Roscommon, MI
If you are not removing trigger, twist lever to the right, little forward pressure, then pull back and out. Spring will be connected to lever by a plastic nub. Can be trying at times. Presence lever front arm must clear trigger.
5155
9:09 PM
pa
Thanks I figured a trick to it.
I'll try as you said but may have to get better eye balls on it.
Glad the trigger can stay put.
5155
9:09 PM
pa
I got it.
Problem with old one was it was not there.
I did have to remove second pin.
This model is different from modern ones
according to parts pics .
Saw is a little happier.
I call this one my work saw because I work on it more than with it.
