51SV CD Ignition Module
dustiebutt
New OPE Member
6:21 AM
Richford, NY
I have been trying to track down an a CD ignition module for my John Deere (Echo) 51SV for a number of years. This was one of the best running saws I have owned for smaller jobs and I really don't want to abandon it. Would appreciate any leads on where to find a module. Thanks all.
mgr1
12:21 PM
Belgium
Is a 2 part ignition? Separate trigger and coil?
vw_motorsports
Active OPE Member
6:21 AM
Check to see if a 46ev is the same, I think I have one of those
mgr1
12:21 PM
Belgium
Maybe it's possible to use a pick up coil from a husky 2 piece ignition.
zgzmithr
Active OPE Member
6:21 AM
NC
That would be great if possible, do you have any idea what you would try first
mgr1
12:21 PM
Belgium
First step would be to see if the bolt pattern is the same between Echo and Husqvarna.
Dolmar made also a few 2 piece ignitions.
6:21 AM
As a suggestion Google "Seek Pro" which is a marketing group that sells on Amazon , E-bay and others .They offer a huge selection of coils .I've never recieved a bad coil . As has already been mentioned usually if the bolt spacing is the same as well as the stator laminations usually it will work .I might once again mention on the rebuilds of two Partner P-100's I found out the coil used on a Husqvarna 272 was a perfect replacement plus after market was inexpensive .It's out there you just need to find it .
