462 Compression
TX_Welder
11:01 AM
SE Texas
Anybody ever put a compression gauge on a stock 462? I put one on mine this morning out of curiosity just to see what it was and I was kind of surprised. It only blew 118 psi and it seemed harder to pull over until it got to peak compression then it seemed to ease up. Strange feeling. I did check to make sure the decomp wasn't pushed in.
I'm 43' in elevation and it was 43° here this morning.
12:01 PM
Those take a small plug that needs a adapter for compression tester right? Guys say they get iffy readings with those.
TX_Welder
11:01 AM
SE Texas
Yeah it was the smallest adapter that I have with my set. A lot of my four wheelers and dirt bikes have the same size/thread pitch. never heard of getting weird readings with the small adapter.
TX_Welder
11:01 AM
SE Texas
Runs like a scalded dog, I was just curious to see what it was. It felt like alot more than that.
I got the saw used so there's no warranty that I'm aware of. I popped the front of the muffler off and looked inside and all looked good.
Manofstihl661
12:01 PM
Texas
The adapter will give you a low reading unless the valve is at the end of it. Or something along those sorts. Most the adapter ones give low readings
qurotro
Cookie Cutter
11:01 AM
Ar
I don't have the adapter for that small plug. But by holding the start rope, my PHO would hold more than 10s before dropping.
12:01 PM
Bingo
The combustion chambers are small, and unless you have a valve at the very tip of the adapter, the adapter volume will be added to the chamber volume. This will give you a falsely low reading.
thesawincanada
For the love of saws
12:01 PM
Ontario, Canada
Just for discussion I got an ms362 from one of my customers who own a tree service saw has tons of hours did a compression test was 170psi. Saw runs like a ravished dog. I end up buying it off of him. He replaces his saw fleet every 4 years so I bought this saw and an ms260.
TX_Welder
11:01 AM
SE Texas
Here's a pic of my setup. Same setup gave me a 150 psi reading on a husky 350 I just put together. I cut .015 off the base on that saw, s20191111_063350.jpg quish came in at .022
That's why I was surprised I only got 120 out of the 462.
blsnelling
Friend of the Riff Raff
12:01 PM
Franklin, OH
Here's a pic of my setup. Same setup gave me a 150 psi reading on a husky 350 I just put together. I cut .015 off the base on that saw, sView attachment 207161 quish came in at .022
That setup will give a false low reading. The volume of the adapter adds to the volume of the combustion chamber to make it read significantly lower than the actual compression. There MUST be a Schrader valve at the very tip that is screwed into the cylinder.
TX_Welder
11:01 AM
SE Texas
Okay makes sense. when I checked the little husky I didnt have to use an adapter.
